IMU Microstrain 3DM-GX3 and the drivers
Hi everybody. Somebody can help my with this IMU? I connected to the computer and I tried to run the LabView example Microstrain 3DM-GXx, and I couldn't obtain data from the IMU with the example.
"Everything that has a beginning has an end"
Message 1 of 12
(8,799 Views)
Greetings, are you getting any error messages? How are you communicating with the device? (Serial, GPIB, USB, etc)
Product Support Engineer
Message 2 of 12
(8,787 Views)
Accepted by topic author anfedres86
The 3DM-GXx drivers were written for MicroStrain's 3DM-GX2 and Inertia-Link products. The drivers do not work on the 3DM-GX3-25 because the communication commands are different. LabVIEW drivers may be downloaded with the 3DM-GX3-25 SDK available on the MicroStrain web site http://www.microstrain.com/updates/GX3_Orientation_SDK.zip.
Message 3 of 12
(8,773 Views)
Ah, thank you for providing that information.
Message 4 of 12
(8,759 Views)
Does anyone have the drivers for the 3DM-GX3 -45? I don't want to reinvent the wheel if someone already created the LabVIEW code for it.
Thanks in advance!
Message 5 of 12
(8,459 Views)
Lisa7603,
The drivers for the 3DM-GX3-45 are available from the same microstrain site referenced in the previous post.
http://www.microstrain.com/software-updates
Should be towards the bottom.
Message 6 of 12
(8,453 Views)
Chris,
I am talking about the LabVIEW code. The 3DM-GXx project does not work with the GX3 -45.
Lisa
Message 7 of 12
(8,449 Views)
Lisa,
Where is the 3DM-GXx project that you are trying to use?  Is it an example from the NI website or one provided by Microstrain?
Message 8 of 12
(8,430 Views)
Well, I couldn't use this driver. It is not working...
Message 9 of 12
(8,073 Views)
LabVIEW sample code for the MicroStrain 3DM-GX3-45 may be downloaded at this link: http://files.microstrain.com/MIP%20LabVIEW%20Sample%20Code.zip.  The Data Communications Protocol manual may be downloaded at this link: http://files.microstrain.com/3DM-GX3-45-Data-Communications-Protocol.pdf.  The LabVIEW sample code is written using the instructions for commands and responses found in the Data Communications Protocol manual.
Message 10 of 12
(8,062 Views)
