INI File, software's slowness
I have a problem with "INI" file.
In a project LabView 8.20, sometime, I have software's slowness when i want to read or write a "INI" File.
For example, normally I read 11 keys in 1 section in few seconds or milliseconds. When the problem occurs, to read or write the 11 keys, it takes more than 2 minutes.
If I execute the vi alone, it works normally.
Do you have some ideas about this problem ?
Jean-Sébastien.
(3,024 Views)
Can you send me a little example to put in evidence the problem.
Regards.
(2,990 Views)
I can't easily reproduce this problem.
I joint you the source of the reading/writing file whose i'm calling before opening the interface (read) and after closing the interface (write).
In pictures, you can see the file's reading operation and this inferface's software.
Regards.
(2,955 Views)
