INSERT STRING ON A TABLE
I have the following table:
Captura.PNG I want to subtract the cell where appear a 10 and the cell where appear a 2, and put the result into the cell at the left. In Excel, it is so easy but i need to do it here in LabView:
I reached do the subtract and on decimal integer string I obtain the correct value::
but now i do not know how to introduce this value into the table.
Please could you help me?
I obtain some issues...
I atach the vi do not see the big case because is invalidated,
Thanks in advance.
(3,480 Views)
Replace Array Subset
(3,474 Views)
you can try:
clicking on the table will result in the active row's 10 to minus 2 and output result in the cell left of 2
CY (expired CLAD)
(3,467 Views)
this is a snippet, save the attachement .png and drag+drop it onto a block-diagram
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(3,462 Views)
so many things to choose from ... have fun
(3,459 Views)
