INSTALLDIR doesn't get passed properly to exe if install directory is a mapped drive
I have a .vi I build into and application and create an installer for using LabVIEW 7.1 and Application Builder.  In the "Advanced..." settings for "Installer Settings" I have configured a .bat file to run (run executable after installation) after the install of my app is complete.  This works fine and dandy if the install location is a simple path to a local disk.  In the batch I register some Active X ocx's, create some folders, etc.  If the install location is changed to a mapped drive I run into issues.  For example, I have another disk on my local PC that is mapped to the Z drive.  If I select the Z drive as the install location, the App installs properly and the .bat file runs correctly HOWEVER the directory I pass to the .bat file (Install Directory) is not passed properly in this scenario.  Is this a bug in Application Builder?
Here is what I pass to the .bat (which is configured in the "Command Line Arguments" of Installer Settings>Advanced):
"[INSTALLDIR]" "[SOURCEDIR]" "qm.lic" "[INSTALLDIR]\Support Files\qm.lic"
Here is the relevent part of the .bat file:
cd %1
mkdir Test1
mkdir Test2
cd Test1
mkdir Configurations
cd %2
COPY %3 %4
As you can see, %1 is the "[INSTALLDIR]".  When I install normally to a local disk (i.e. Program Files) this gets passed properly to the batch.  I know this because the directories "Test1" and "Test2" are created properly in the installed location.  However, if I install to a mapped drive, the  "[INSTALLDIR]" is not passed properly.  The "Test1" and "Test2" folders are created in the system32 folder.  It is like it cannot associate the INSTALLDIR with a mapped location so it defaults to the system32 folder.  Any insight as to what is going on here would be much appreciated.
Steffan Benamou
(3,569 Views)
Try to put "echo %1" in your batch file to see what is passed as argument. That would give some hints.
LabVIEW, C'est LabVIEW
(3,561 Views)
Thanks for the reply.  Good point...
Here is what I get (%1 echoed) when installed into a local directory for INSTALLDIR:
"C:\Program Files\Program1\"
Here is what I get if I choose a mapped drive.  I have mapped drive Y: on my PC to a particular shared folder on my local machine:
"Y:\"
The system cannot find the path specified.
It looks like it just can't find the location, however all the files that I have linked in the Installer in "Installer Settings>Files" specified as "Install Directory" get added to the proper location in Y!  I would think that the Install Directory path should just get passed to INSTALLDIR path or they should be one in the same.  It seems they are not.  Any ideas?
Steffan
(3,559 Views)
The cd command doesn't change the drive unless you explicitely include the /D switch.
The command
cd /D %1
should work in all cases, changing drive or using the same.
(3,552 Views)
Ahh.  I see whats goin on.  Stupid mistake.  The returned error is from the cd.  Thanks for the help!
(3,549 Views)
