IP IMAGE
And the VLC method I linked to earlier?
Message 11 of 16
(1,421 Views)
@VINICIUSALLAN wrote:
it gives me this information in the "body" and "headers" field and I don't know how to proceed after that
I suppose you will have to parse the contents of the body.
Bill
CLD
(Mid-Level minion.)
Message 12 of 16
(1,419 Views)
I tried it with the VLC method that you gave me, but it's giving this error
I also got lost on which VI to use for my problem.
Message 13 of 16
(1,415 Views)
If you open the context help and hover of the missing VI you'll see it is asking for a VI that you didn't download from that example code.  Download all then open the "VLC - Play Stream&Snapshot&speed.vi".  Provide the media source, and run it.  Make sure you have VLC x86 version if you are using LabVIEW 32 bit.
Message 14 of 16
(1,401 Views)
the VI worked, but I don't understand how to link with the IP was the image to appear in picture BOX?
Message 15 of 16
(1,393 Views)
When I saw this error in the past it was because I was using the 64 bit version of VLC and the 32 bit version of LabVIEW.
"I downloaded the latest version of VLC Win32 from here, then made sure that the DLL path to libvlc.dll, was to the one in the Program Files (x86) folder."
Message 16 of 16
(1,367 Views)
