IP Virtualization in LabView
Hi all,
I'm looking for a idea or suggestion about a this problem.
- I need to emulate some application sw inside LV enviroment on PC (Win Based).
- The emulated SW send messages via TCP/IP to my target devices and for it is
   mandatory recieves messages, on my target, from different IP.
- On my PC I've only one ethernet port, so I need do overwrite the native IP with IPs await by my target.
How can do this? If possible without using virtual machine.
(3,279 Views)
Can you not use 127.0.0.1 (localhost) with a different port for the sending vs. receiving?  That should work ok for testing purposes.  There are example server/client code that ships with Labview that use a similar setup.
aputman
(3,274 Views)
Is not possible because my tagets check the messages outgoing from different IP and it use this information as lifesignal to avoid the alarm presence.
On web I found some thread about this problem (out of LV) and seems that the solution is NAT application.
have someone experience abouth this?
(3,267 Views)
