IPC CFX in Labview
Does anyone know of any development of IPC CFX in Labview?  http://www.ipc-cfx.org/
We may soon be using aegis which supports CFX i have been tasked with seeing if it is possible to modify our existing labview applications to redirect its results in to aegis using CFX.  I cant' seem to find any information and so far this looks like a very new standard.  If it is something NI will be looking at i can see it being a chargeable toolkit addon.  however i don't see why a basic implementation of it can't be achieved as it seems to be using an XML based system.
I am just looking for any information anyone has
(3,608 Views)
Hi Dave,
I don't believe there is a direct plug-in for the use of IPC CFX within LabVIEW although I have found the following document which mentions CFX as an output.
LabVIEW Communications 802.11 Application Framework 2.0 and 2.0.1
Is this similar to what you were looking for?
Also, I believe it is based on Microsoft .NET according to the following article which can be used within LabVIEW.
Connected Factory Exchange Implementation
https://www.ipc.org/ContentPage.aspx?Pageid=New-Software-Toolkit-CFX-Messaging-Library-Expedites-Con...
I hope this helps!
Jaimie
(3,562 Views)
