Hi everyone,
Specifications
- LabView 2016
- NI-USRP driver : 16.0
I'm trying to create a labview project to record and playback IQ data from AM modulation.
First Step, I generate a AM signal through a generator with this settings :
- Carrier frequency : 1 GHz
- AM freq : 2.500 kHz
This signal is then received by an USRP-2954R through a coaxial cable.
Then In order to do the record, I decided to apply this settings:
- Number of samples : 1000
- IQ rate : 500k
Record program
After this step, i created another program to playback my IQ data with these parameters:
- IQ rate : 500k
Playback program
Finally, I use a Spectrum analyzer to check the quality of my playback signal. Unfortunately, after many tests, I still can't get a clean signal
Any suggestions would be most welcome.
Thanks!
