12-16-2009 02:34 AM
I think it is the first, because E - back emf (call it B here) = V (terminal voltage) = IR ( R = resistance of coil)
So EI - BI = I^2 R Giving EI = BI + I^R
The EI part gives the input electrical power
I^2 R part is the power dissipated as heat
Therefore BI must be the mechanical power developed which must be the same as force x speed = Wv
So efficiency = BI/EI = Wv/EI
What do you think?
12-16-2009 03:24 AM - edited 12-16-2009 03:24 AM
Hi Dan,
"What do you think?"
I think this is a Mechanics homework ![]()
Also this question is not LabView related, so why not look for wikipedia or some fundamental Physics forum?
You have not explained what source voltage refers to...
