IS there a way to eliminate noise or smooth data aquired from an SCXI-1000?
I am running an AT-MIO-16E-1 with an SCXI-1000 and an SCXI 1120 card. The data that I aquire from this is full of noise, but well within the specifications from NI. I am sampling at 5000S/s and was wondering if I could write a component into the Labview Interface that would smooth this data or provide me a trend of the data eliminating this noise. For some reason, and I believe it is in the software, this 15 year old macintosh yields better data and I believe that there is some smoothing routine in the Labview 2.0 fucntions that it uses. If you have any suggestions, please recommend the names of the componets that I would need to wire in, and I will read up on how to do it. If you would like
I could supply the code that I am using too.
Joe
617-452-3250
(3,002 Views)
One good way of doing this is with a Waveform Average vi. I believe there's one in the NI code exchange archives. This works with any array or waveform.
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(3,002 Views)
Joe,
Here are some links that discuss digital filtering in LabVIEW. I just did a search on the web site for "labview digital filter".
How Do I Select the Correct Filter in LabVIEW for My Application?
Reducing Noise Using Digital Filtering in LabVIEW
In addition LabVIEW 7.0 has an express VI that does filtering of signals.
Evan
(3,002 Views)
