ISM 7413
Hi All,
I want to Interface NI ISM 7413 stepper motor with the LabVIEW.
Do I need to have a separate I/O device for interfacing or can it be directly connected to PC?
If it can be connected directly to PC, how do I interface stepper motor driver with the LabVIEW?
In the manual, they talk about NI Stepper configuration utility software. But couldn't find it on NI/downloads. Could you please help
Thanks in advance.
(3,453 Views)
Here is the link for NI Stepper configuration utility software:
https://www.ni.com/en-us/support/downloads/drivers/download.stepper-configuration-utility.html#33112...
Sometimes, Google is better.
You need a driver: NI-Motion
Be aware that step motor is going to obsolete by the end of June.
George Zou
(3,378 Views)
Thanks for the reply Jou. ISM7413 stepper motor comes with driver. Do I need a separate I/O device for interfacing with LABVIEW?
(3,345 Views)
It's a "smart" motor, has controller built-in.  You can connect to it directly without other device.
George Zou
(3,336 Views)
