ISVI IC-M29 camera
We purchased an ISVI IC-M29 camera about 5 years ago and was never able to make it work.
I could not find drivers and software for it.
Here is what I have done so far.
  1. The User Manual states that: "The Camera Control Tool is a program provided to users to control all parameters of the camera and to save the desired settings to user pages for later recall. Always use the latest version of the Camera Control Tool for your camera. You can download the latest version from www.isvi-corp.com or contact your local ISVI agent." Never been able to find the Camera Control Tool. If any of you have a link to that software provided by ISVI, please help me out.
  2. I purchased a PCI Express x4 Camera Link Frame Grabber (and also a PCI Express x8 Camera Link Frame Grabber), plus cables. The XCAP-Lite software is extermely limited (only can save on TIFF frame at a time). However, even with XAP-Lite, instead of 6576x4384 resolution of the camera I can only get \6576x3400 (or less). Do any of you have any idea if this a limitation of the XCAP-Lite and it will go aways if I purchase the otehr XCAP licenses? Did any of you ever manage to use IC-M29 camera with XCAP? Whay frame grabber?
  3. I purchase a NI chassis NI PXIe - 1073, added a NI PXIe-1435 Image Aqusition borad and pout it inside the NI chassis (see attached picture). Connected the NI PIXe-1073 with a cable to a board in Windows 10 PC (the borad insiode the PC is NI PCIe-8362. Obviously, NI Measurement & Automation cannot connect with ISVI IC-M29 becasaue there is no such driver from NI. The only camera driver I found that is compativle with NI was iSVi IC-C25_mono.idc, which always returns Error 0xBFF6902C "Unable yo connect to the camera." Do any of you know of such a camera file for ISVI IC-M29?
Thank you.
Message 1 of 1
(2,602 Views)
