ITS-90 RTD Calibration
I am working with some RTDs that I got calibrated at my company's in house calibration lab. The data sheet I got had ITS90 coefficients, but I only see an option to adjust for Callendar Van-Dusen coefficients. Does anyone know how to use ITS90 coefficients in LabVIEW or get the resistance measurement from the RTD so I can use the ITS90 coefficients in my post analysis?
Thanks!
(2,882 Views)
Hi Abigail,
I guess my first question would be, how are you planning to measure the RTDs? (I also don't see CVD coeffs on the DAQmx AI > Temp > RTD option, which was what I first guessed you were looking at).
If you can measure a voltage, you'll have an easy time post processing, but this requires some arrangement of your resistors, current or a reference resistor, etc.
GCentral
(2,836 Views)
I'm measuring the RTDs with an NI 9217 cDAQ. The cofficients I'm talking about are the a, b, c, and Ro values if you use a custom RTD.
Thanks!
Abigail
(2,794 Views)
