IV Characteristics of diode using Keithley 2450
Accepted by topic author beginner1234
Hi beginner,
@beginner1234 wrote:
I need to plot an X-Y graph between Voltage and Current, then which parts of the block diagram must I eliminate, and which voltage and current output do I connect to X and Y axis of the graph?
As the context help shows: build two 1D arrays from your voltage and current values, then bundle both arrays into a cluster. The XY graph accepts a cluster of [X array, Y array) for a plot…
Message 11 of 20
(1,403 Views)
What exactly I am trying to understand in this block diagram is where the voltage and current values are to build the array.
Please explain through the block diagram and I am really sorry for being a nuisance and thank you.
Message 12 of 20
(1,397 Views)
In the examples that came along with instrument drivers of Keithley 2450, there is one example for pulse and acquire measurements, and I have tried to perform it by connecting the 2450 device, but it shows error1074000000. Upon going through all the functions in the example, it is clear some of them are compatible with only 2461, but I only have a Keithley 2450 and need to perform a pulse with that device, what do I change or modify?
Also how do I get a Current vs Voltage graph instead of Current/Voltage vs Time graph? As in where exactly are voltage and current output terminals that are to be connected to the XY graph in this block diagram?
Message 13 of 20
(1,381 Views)
Hi beginner,
Read the manual of your device to learn how to configure your measurement requirements.
Once you know "how to configure" manually you can implement the same using SCPI commands…
You have been told to downconvert your VI before attaching as you are using the very latest LabVIEW version. (I even prefer LV2019.)
Instead of helping us to help you you even started a new thread with the very same question: why do you think spreading a discussion over several threads would help to solve your problem?
Message 14 of 20
(1,371 Views)
I apologize, it was not my intention to do so and I did not know how to down convert before, thus I provided the screenshots of the same. Now that I know it, here is the example I am talking about in 19.0 version
Message 15 of 20
(1,357 Views)
Hi beginner,
I guess you get current and voltage values from your Read function when you use the decimate function to split the data into two plots of your waveform graph. To create a XY plot you could use the bundle function (as shown in the context help of the XYgraph):
Message 16 of 20
(1,358 Views)
Thank you, this might work the way I want it, but I just tested this on a sweep example but both waveform and graph are not working. I tested it with an LED whose limits I know, there's a light indicating sweep going well but the graphs aren't showing. What might be the problem?
And is it possible to save the image of the graph?
Message 17 of 20
(1,341 Views)
Hi beginner,
The problem might be the response of your device - I don't have that hardware and so I cannot run your VI.
Which string response do you receive? Does it contain the data you expect for creating your plots?
You need to do some debugging on your own!
Yes.
Use a method of the graph to export the image!
(Most often it is more useful to save the measurement data instead of images of some graphs…)
Message 18 of 20
(1,336 Views)
The data I need is an IV graph and I cannot confirm if the string gives current and voltage since the graph did not work but I was advised to create the XY graph in the way I did in the block diagram from this community. The device does well on other software and gives the graph properly, so what debugging should I do?
The image is also required along with the data so I will try the method you suggested.
Thank you.
Message 19 of 20
(1,333 Views)
Hi beginner,
I cannot confirm if the string gives current and voltage since the graph did not work …
Because the "graph doesn't work" you cannot verify the string content?
What about using probes and indicators???
As I wrote before: do some debugging on your own!
Message 20 of 20
(1,330 Views)
