IVB Geometry.llb>>IVB Geometry Exec.vi >> IVB Geometry-Algorithm.vi >> IMAQ Bisecting Line Block Diagram ERROR
pc : notebook windows 2000
tools : labview 7.1
          vision buielder AI 2.6.1
content: convert from vision buielder AI to  labview_code
IVB Geometry.llb>>IVB Geometry Exec.vi >> IVB Geometry-Algorithm.vi >> IMAQ Bisecting Line Block Diagram  <- calculation ERROR
Input Data is
Line1: Point1:X:255.9 Y:154
          Point2:X:255.9 Y:196
Line2: Point1:X:316.1 Y:152
          Point2:X:316.1 Y:194
Bisecting Line : Point1:X:0 Y:0
                         Point2:X:0 Y:0
Output  Data is
Bisecting Line : Point1:X:316.1 Y:2.76171E+7   <= Error
                         Point2:X:316.1 Y:2.76171E+7   <= Error
(2,475 Views)
That's doesn't sound good. If you didn't miss in telling us an important detail it seems to be a bug.
To enable me (and all the other people looking at the forums) in reproducing the problem you should post your inspection (saved with VBAI) side by side with the image you used to produce this bug.
I have the Vision Development Module 8.0 installed. The IMAQ Bisecting Line.VI does not show up this problem. It has a well-behaved output.
Another recommendation: A good location for this post would have been Machine Vision.
Best regards, Guenter
(2,466 Views)
