IVI drivers & Rigol DSA1030A
Hello I want to use this instrument with labview. Checking on the "Find driver instrument" I haven't found it, so I followed these steps:
http://www.ni.com/white-paper/3377/en/
but I'm not able to get the same results...since what I got is shown in the figure:
how can I see and rename the rigol in max?
Thank you for the help.
(3,686 Views)
Hi inuyasha84.
I did a search and found this post: How to communicate with SCPI using Labview?
They are talking about the same instrument and that a driver can be downloaded from the manufactors webpage. Have a look here:
http://www.rigolna.com/products/spectrum-analyzers/dsa1000a/dsa1030a/
Best Regards
Alex E. Munkhaus
Certified LabVIEW Developer (CLD)
System Engineer
(3,677 Views)
It looks like you have the Rigol IVI driver already installed so I don't understand your question.
(3,660 Views)
Hi
What do you mean by rename rigol in max?
Genearlly, there are two types of instrument drivers: Plug&Play (simple, easy to use) and IVI (complex, powerful i.e. simulate live instruments). Not sure if you are indend to use the IVI instrument driver. If your requirement is to control the instrument and get back the measured data to PC. It is okay to select the LabVIEW PnP (Plug and Play) drivers.
Please search the instrument model in "Find driver instrument" again to installer the driver.
 Chenchen
(3,628 Views)
