IWebBrowser2 ActiveX object opens in a very small window.
I'm using the IWebBrowser2 (see the attached vi) to enable the user to preview a generated HTML report prior to printout. The function works fine for itself, but for some reason when called from inside my application, it opens in a very, very small window, which is quite irritating, because then the user has to resize the window every time it opens. Does anyone have experinces with this problem or can think of a solution to this problem. Is it fx. possible to programmatically change the size of the opened preview window?
Best regards
Stenbo
(2,759 Views)
How about using Open URL in default browser from the Application Control>>Help palette?
___________________
Try to take over the world!
(2,752 Views)
