IXXAT USB-to-CAN CAN open
I'm trying to interface IXXAT USB-to-CAN V2 with Labview trough the library found at
https://www.ixxat.com/support/file-and-documents-download/drivers/vci-v4-driver
I can connect to the hardware with the 'VciDeviceOpenDlg', then I don't know what to do after
Someone has any example or hint to suggest?
Thank you
(8,616 Views)
(8,592 Views)
Yes, In fact I installed those, but I need some example to receive and interpret data
i.e.:
  • Connect to the device
  • Create a channel
  • Read message
I don't know where to start, I tried to search but the only example link I found were 404 pages
Thanks, BR
Alice
(8,564 Views)
Accepted by topic author Alice88
I found a solution for my project
unfortunately I cannot load the entire VI, but I can load a picture
First you need to open the device and the controller (once) and then to use the channel to read and send messages
(8,369 Views)
