Icon Labels on functions palette not appearing
I have a very simple problem. I'm using LV 2009. Usually, there are labels underneath each icon, but now I have to mouse over the icon for the label to appear in a blue bar at the top of the palette. Is there any way I can change it so that the default has the full icon name appear? I hope my description of the problem was clear enough. Please let me know if yo need more details.
Thanks.
(4,597 Views)
Accepted by topic author peeroe
go to the view button on the top right corner and than view this pallette as and select which one you want
Message Edited by Harold Timmis on 09-15-2009 02:21 PM
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(4,596 Views)
Never had to change that before....
(4,586 Views)
Greetings folks,
 This issue has seem to come back in LabVIEW 2024 Q1. It doesn't seem to remember the setting. You have to enable 'Icons and Text' each time you use the functions palette. Am I the only one seeing this?
https://discord.com/channels/1015999107921354932/1156357099194953799/1209893460669239367
(1,498 Views)
Much thanks to dnatt for saving my sanity:
"Did you check your settings? This is ultimately saved into labview.ini, Tools >> Options >> Controls/Functions Palettes >> Formatting >> Palette set to "Category (Icons and Text)"
Another crisis averted...
(1,489 Views)
