Icon editor lock up in LV2009 for Template VIs (.VIT)
I have reproduced this on two different LabVIEW 2009 installs (two different PCs).
Setup:
 - I create a VI and save it as a Template VI (.vit) and then I try to edit the icon for the .vit by right clicking on the icon and selecting "edit icon".
What happens:
 - The icon editor does not open and I cannot close the .vit.  I can still make changes to the .vit, but I cannot close the .vit without using Win Task Manager.
Any Ideas?
Message 1 of 11
(4,453 Views)
By the way, this is LabVIEW 2009 with the f2 Patch installed.
Message 2 of 11
(4,452 Views)
Hello Chris,
Thank you for the report. I have submitted a corrective action request (CAR#194720) to our R&D group and this issue will be addressed in future releases of patch/LabVIEW. By the way, I was able to use LabVIEW 8.6 without this error.
Andy Chang
Message 3 of 11
(4,431 Views)
Chris,
sorry for the inconvenience.
I have put a patch online which should avoid this problem. I have checked it on one of our test machines and it seems to work.
http://decibel.ni.com/content/docs/DOC-6301
Tom
Message 4 of 11
(4,421 Views)
ThSa,
This patch did not work for me.  I restarted LabVIEW as it suggested, since that did not work I tried a PC reboot, still no luck.
My workaround has been to save the .vit as a .vi, modify the icon, and then save as a .vit.
Thanks.
Message 5 of 11
(4,409 Views)
I have exactly the same problem, and the patch did not work for me either.
Svein
Message 6 of 11
(4,366 Views)
We are currently invesitigating this issue further and will address this in the near future.
Andy Chang
Message 7 of 11
(4,347 Views)
If you double-click on the icon, the icon editor should open.  I've only reproduced the issue by using the right-click menu shortcut for the icon editor in a .vit.
To reproduce the issue:
  • From a .vit right-click the icon and select "Edit Icon"
To avoid the issue:
  • Double-click on the icon to open the icon editor
This appears to work on my system, any other takers?
-Bob
Message 8 of 11
(4,334 Views)
Bob,
I just tried double-clicking on the icon and it works for me.
Its not my habitual way of editing the icon, but its better than the work around I was using (listed previously).
Chris
Message 9 of 11
(4,327 Views)
Double-clicking works! I didn't know this way of opening the icon editor. It's almost too easy. So I guess I learned something new today 🙂
Svein
Message 10 of 11
(4,305 Views)
