Icon editor text squinching when add some glyphs
In LV2015sp1 icon editor, I get problems where the text compresses and tries to fit into the vertical space of one of the glyphs in the image. Example attached.
Often happens when adding a VI to a lvlib and applying the lvlib icon, or when modifying an icon on a vi that's been created as Save A Copy.
Happens fairly often, and is frustrating to work around (basically I either remove the glyph or hand-redraw the glyphs and the text behaves normally). How to fix or prevent?
(3,527 Views)
I reported this and posted it on the LabVIEW Idea Exchange here.  I was told that this had been fixed, verified that it seemed to be fixed, but then found it wasn't fixed.  I did not manage to follow up at NI Week 2016, but hope to do so at NI Week 2017.
Bob Schor
(3,488 Views)
Nope, not fixed. And your Idea was closed, so I can't upvote it. I haven't verified that LV2016 has the same problem.
Did you ever find a workaround? Deleting the layer with the glyph and redrawing the glyph on another old layer (can't be a new layer) is the only thing that works for me consistently.
Bob Schor
(3,479 Views)
Accepted by topic author lgc102
Well, I did find a work-around.  What I was trying to do was to create an Icon Template for an Icon that I saw Aristos Queue use -- the Icon looked like a While Loop, and was mnemonic for a VI that ran (as a loop) asynchronously.  Here's a picture of one of my "Loop" VIs (it displays Video images), the Template I wanted to use, and the "workaround" Template I ended up using.Loop Template.png
You'll notice that the template has a double-thick rounded border (like a While Loop), with arrow.  If I made a template that looked like the middle one, the text tried to insert itself between the bottom two lines (bad!).  So I made a one-line-on-the-bottom template (last example), and when I select it, I draw in the additional bottom line (it appears as a Layer), and all is well.
The "trick" is to avoid double lines on the bottom (they are fine on the top).  You also want to do the minimum amount of "hand-fixing" (I only needed to draw one obvious line).
Bob Schor
(3,470 Views)
For work around, have you tried removing the template?
or use a simple 32x32 square frame?
George Zou
(3,462 Views)
