Identificación de personas por voz
Buenas tardes estoy tratando de hacer un programa en labview que me permita identificar una persona por su voz, es decir necesito introducir su voz y compararla con la voz previamente almacenada y si esta es igual permitirle abrir una puerta,.... Agradecería cualquier información de como hacer esto y que debo utilizar...
(2,872 Views)
His message translated by google:
"Good afternoon I am trying to make a labview program that allows me to identify a person's voice, is need to introduce your voice and compare with the previously stored voice and if this is just let you open a door ,.... Would appreciate any information on how to do this and that I should use ..."
[will work for kudos]
(2,867 Views)
You can see the following examples:
Usted puede ver los siguientes ejemplos:
http://zone.ni.com/devzone/cda/epd/p/id/4401
http://decibel.ni.com/content/docs/DOC-4477
http://decibel.ni.com/content/docs/DOC-2302
Cordiales Saludos,
Abel
NI Brazil
Spanish by Google.
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(2,850 Views)
Good afternoon links that I have published I have been very helpful as I have not had much luck in what I'm doing because I am no expert in labview I have only basic knowledge ... appreciate that someone could give me other information .. thanks for all the people who welcomed my question ,....
please if anyone can help me otherwise maybe ,....
(2,820 Views)
