Identification of the first element of a 1-D array
Hello.I am collecting a continuous data(1-D array)into a while loop and I would like to extract the first element, when I use the index array(index 0)I have a variable value, is this maybe because the data is continuos??Could somebody help me, thanks in advance, Asahel
(2,526 Views)
How are you building up the continous array inside the while loop? Is it possible that you are appending the new data at the beginning? Is it possible that the new data replaces the old array data?
Could you attach a simple example of what you are doing?
(2,526 Views)
