Identify several AIM ARINC Boards on a bench
Hello everyone!
I'm developping a software that shall pilote 2 AIM ARINC boards : ACX429 8, using the BSP v8.
For each board there is a bmodule that is an integer identifying the board. When there is only one board in the bench the bmodule = 0.
But when there is 2 boards, how can we tell which one is 0 and which one is 1 ?
Thanks for your help!
(3,230 Views)
Can you retrieve the s/n of the board?
(3,227 Views)
Yes, I have access to the PXI chassis and if the S/N is as usual on the board, I can retreive it.
(3,222 Views)
I think he is asking whether you can read, electronically, the board s/n
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,217 Views)
Exactly.
Retrieving the s/n of the board (programmatically) let you pair the id (0 or 1) with the physical object.
That's what I did with Ballard ARINC boards, but should be possiblie also in your case.
Regards
Marco
(3,215 Views)
Actually MarcoMauri was write.
I know how to get the serial number. The problem that I'm facing is that it seems like I can only pilote one board at a time. I can access by soft the S/N of each board if there is one board in the PXI. As soon as I put both in, I have systematically an error on the second S/N request.
(3,195 Views)
