Identify typedef
Is there a way to identify typedef as strict or just plain typedef programatically? I could not find a thread on this in forums.
Ya Ya
(5,057 Views)
Only idea I have: Try to change a property that you cannot change for a strict typedef. If you get an error, it is a strict typedef. If it is not, you can change the property's value back to the value it had before the change.
I think that no common property exists that you can use for this. This prevents you from doing it the generic way.
Does anyone have a better idea?
Regards, Guenter
(5,028 Views)
Use the node in the attached .vi
(5,016 Views)
Thank you both for your help. My next question in the same line is
Can we dynamically open a strict typedef cluster and save it to typedef
cluster?
Ya Ya
(4,987 Views)
It's the same as looking to see what type the control is, you just write to the property node instead of reading it.  Open a VI reference to the control, use the property node CtrlVIType and wire in a constant of typedef to it.  Just like the VI I have attached.
Brian Coalson
Software Engineer
(4,958 Views)
Brian,
          This is the one I have been looking for. Thank you so much 🙂
-Vasanth.
Ya Ya
(4,892 Views)
Nick,
Is it a Private property, I mean, NOT available in LV 7.1 ?
Please clarify me...
- Partha ( CLD until Oct 2027 🙂 )
(4,881 Views)
