Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
If I call a batch file with parameters with the system exec I get the message "Out of enviroment space"
semmar1
Member
04-22-2004
06:27 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
The command Line looks like that:
command.com /C go.bat "Parameter1" "Parameter2"
go.bat starts but withe the message "out of environment space" and the parameters are not transmitted.
0
Kudos
Message
1
of 2
(2,620 Views)
Reply
Re: If I call a batch file with parameters with the system exec I get the message "Out of enviroment space"
PatrickB1
Member
04-29-2004
07:11 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hallo,
This VI have some limitations. In the attachment you find Zip-File and when you look in the Readme.doc you will find System exec+.vi. It should go with this VI.
Greetings
PatrickB
lvwutil32.zip 634 KB
0
Kudos
Message
2
of 2
(2,620 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
