If I create a program with Vision Builder, will it work with a LabView driver?
(2,928 Views)
You seem to have clicked the 'Post' button before you had a chance to use the message body to explain your question.
(2,923 Views)
I have a BitFlow frame grabber with a LabView driver. If I write an application with Vision Builder, will it run with the LabView driver? Basically, Is Vision Builder and Labview compatible at the driver level?
Thanks!
(2,917 Views)
Hey Bob,
I'm not really sure what you are asking.
First off, VBAI was compiled with LabVIEW 8.5, so yes, they are compatible.
Are you trying to use your image from LabVIEW in VBAI? Are you trying to acquire from your camera in VBAI? Could you pleas clarify for us.
Chris Van Horn
(2,895 Views)
Hi Chris,
A Vision Builder customer wants to know whether a progam they write with Vision Builder will work with a BitFlow Frame Grabber, using the  BitFlow frame grabber's LabView driver.
Thanks!
(2,880 Views)
My answer is going to be yes for this, though it may not be an extremely simple solution.
As I said, VBAI was compiled in LabVIEW, so there is no issues there, the only problem I am seeing will be getting your image from your camera, and being able to read it with VBAI.
You could always put together some code that would populate your VBAI image buffer with your iamge from your BitFlow frame grabber, then do the inspection from there.
You might want to look at this KB which shows you how to use VBAI and a non-supported USB camera. Obviously, the exact method will differ, but the concept is the same.
Chris Van Horn
(2,848 Views)
