If I upgrade from 6.0 to 6.0.2, will other machines that run my EXE files need to have something loaded on them?
I understand that I should copy the new lvrt.msi file onto MY machine. There are a few other machines, which have the Run Time Engine only, that run my exe's. Do those machines need to be fiddled with?
Richard
(2,363 Views)
Hello Broken Arrow,
You should have the same version of runtime engine as your Labview. That means to run an application that was built in 6.0.2 you would have to have 6.0.2 runtime engine.
Hope this helps.
Good Luck.
Shruti T
(2,363 Views)
