If i have a LV FPGA program, will i be able to get a wiring list for that program so that i can download it into some other FPGA?
after doing rapid control prototyping using 7831R and LVFPGA, if i decide to build the custom chip, can i use the LV code that i've alredy built or i'll have to do the coding again in VHDL
KAliDas
(2,968 Views)
The LabVIEW FPGA module currently does not expose the VHDL code to you and will not download the code to non-NI hardware. However, it will allow you to quickly provide a 'proof of concept' if you are planning on using a custom chip in the future.
JR A.
Application Engineer
(2,968 Views)
