If you update a graph on the main vi in a subvi by wiring a reference, the graph on the main vi lags behind one reading
@Sarci1 wrote:
Hi SegmentationFault,
I looked into this issue a bit further and compared it to the response of an XY graph and you are correct the behavior is faulty.  I am going to file a Corrective Action Request on this issue.  For now, however, I would suggest using the workaround of output the last data set from your subVI to your main VI.
Thanks!
Lynn
Could you please post the CAR once filled.
Ben
Message 11 of 15
(1,059 Views)
The CAR for this issue is #278933.  Thank you for bringing it to our attention.
Senior Systems Engineer
Message 12 of 15
(1,050 Views)
Oh, so it was a bug within labview? Well that was a bit unexpected. Is there a way to know when this is resolved/receive the fix?
Message 13 of 15
(1,042 Views)
Unfortunately there is no way to know when a CAR will be fixed.  However, you can review the Release Notes for each version of LabVIEW.  If the CAR has been fixed that number will appear within.  For now, I would suggest using the workaround provided which outputs the last data set from the subVI to the main VI.
Message 14 of 15
(1,039 Views)
In my case I worked around it by placing case structure after my event that is executed after teh event but only if there was a change.
I sorta thought it was working like the Image control that does not update when I expect.
Ben
Message 15 of 15
(1,026 Views)
