Ignition Switch to use in a Labview panel?
Has anybody programed vehicle ignition switch to use in a Labview panel to interface to a simulator?
(3,034 Views)
Chris,
I don't have experience in designing such systems, but here is one document that I think will help you in your design.
Building Flexible, Cost-Effective ECU Test Systems
I was able to find few other articles when I searched on Google for "ignition switch" and labview.
Zvezdana S.
(3,034 Views)
What do you mean by "programmed vehicle ignition switch"?
Do you want LabVIEW to respond when a real switch is turned, a graphic that looks like an ignition switch, or any switch that gives an "On" value while it is being clicked but "Off" otherwise, or an "Accessories, Off, Acc+ignition, ignition+Starter" graphic/trinary output widget?
Les
(3,034 Views)
