Ignore Inf during operation
I'm cablibrating a set of thermocouples and want to get a standard deviation to see how well they are tracking each other. The problem is that I don't always have all channels connected, but don't want to change my array size when a junction is open. My DAQ card returns -9999 when it detects an open junction, which is fine. However, if I pass it an array of 8 values, and 4 of them are -9999, that has a big effect on the summary statistics. I tried using a comparison to replace -9999 with NaN in the array, but it seems to treat those as Inf, which also affects the standard deviation.
What I'd really like is something like the NaN toolbox for Matlab, which will conduct matrix operations ignoring NaNs... Does anyone have any simple suggestions?
mike
(4,021 Views)
Before you take the aggegate value of the array, you could sort the array and use the sub-array that does not contain -9999.
That would be SORT:THRESHOLD:SUB-ARRAY:AVERAGE
(4,019 Views)
That'll do the trick...
thanks,
mike
(4,015 Views)
