Ignore changes when closing LabVIEW from command line
Is there a way to ignore changes when closing LabVIEW from the command-line? So that LabVIEW doesn't halt the exit with a save prompt.
I'm trying to get an automated build server going and want to be sure that LabVIEW is really closed on the remote server and not stuck in an unknown state.
(3,514 Views)
How are you closing LabVIEW from the command line?
Also, are you always running into the issue with LabVIEW being stuck on a save prompt when closing?
Cheers,
Kevin
(3,463 Views)
C:\>Taskkill /IM LabVIEW.exe /F
This is nasty... I'd consider it a last resort.
(3,450 Views)
Definitely want to stay away from Taskkill as it doesn't close LabVIEW properly and could lead to a crash.
(3,441 Views)
