Iinstall VI on any windows PC
This is a Lab View file and I need to develop a stand-alone executable file of that file to be installed on any windows PC
(3,470 Views)
LabVIEW is really great at distribution for execution outside the development environment. You can build just an executable, of an entire installer that includes all of your dependencies as well.
Check out this article for instructions.
Cheers
(3,469 Views)
Can you do it for the attached file. I,m still training and this is an assignment with 4%
(3,462 Views)
Sorry, I don't understand. So, are you training to be a manager and have others do your work for you?
(3,449 Views)
This VI is not suitable to be turned into an executable, it does not even have a toplevel loop. If this is really a LabVIEW course, You need to re-architect your code into a proper state machine if the target is a windows executable. Who wrote this? Who came up with that horrible color scheme for the front panel?
In addition, it has many beginner mistakes (wrong representation. e.g. "Enter Heat Transfer Mode Number " should probably be an enum, not a DBL). Simulate and RMS belong before the case structure because they are identical in all cases. Only one instance needed. The difference in processing comes only later. Right?
(3,436 Views)
I think it's a school assignment and making the executable is 4% of the grade...
Cheers
(3,433 Views)
Yes, I got that and I predict a failing grade.
My comment was sarcasm 😮 (with deep undertones commenting on the inherent difference between programmers and managers :D)
We should not gloss over that and help giving an undeserved grade boost. 🙂
(3,428 Views)
