Im a student having trouble with a Municipal Water Managment System Project......Help please !!!
What i meant was i've got a half assed program done up messing about with the tank simulators in LabView, enough to prob grab about 50% so it's cool if your busy, it's nearly for my own interest at this stage 🙂 , it'd be nice to learn some proper code writing right from the start....But i don't know where to begin!!
Message Edited by Simone 27 on 05-26-2010 03:45 AM
Message 71 of 77
(1,182 Views)
You had defined the requirements and we were considering the code architecture.
Since you have the Professional version, I suggest the Producer/Consumer Design Pattern with Events.  The events will be passed to the consumer loop to change the state when the operator makes a selection. You could use the explanations that I provide to document your code.
The code template, excluding the tanks and their associated code would look like this:
Message Edited by Ray.R on 05-26-2010 07:55 AM
Message 72 of 77
(1,163 Views)
Ok, i get the idea....little lost, but am following 🙂
Message 73 of 77
(1,154 Views)
Well, the step before this one should be to define the events; both user and automated-control.
So a state diagram would come in very handy.
The next step would be to create the Front Panel controls for each of the controls that you identified in your design.
I'll do an example using the original code that I posted.
Message 74 of 77
(1,134 Views)
Thank you.....
Message 75 of 77
(1,118 Views)
It's a very busy day today.  Hopefully, I will complete the example before the end of the day.
Message 76 of 77
(1,110 Views)
No problem, thanks again 🙂 and really don't put yourself under pressure, like i said i've  got enough done to pass.... I'd just love to see my full idea developed, it was a good one if i do say so myself 🙂 Haha....self praise is the best kind....
Message 77 of 77
(1,102 Views)
