Im creating a simple PID controller, however i cannot graph the output
I have created a simple PID controller but the output cannot be drawn on a graph as i have connected two different types. I have my file attached, Is any one able to assist me
(5,172 Views)
I'm using 2014 so I can't open your VI.  It looks like it's a simple data type mismatch.  Change the graph to be a double datatype.
Are you using an array of data from the PID? I thought it was a single scalar value.  In that case, you'd want a chart instead to keep updating your history as you go.  The graph won't maintain a history for you.
(5,163 Views)
Well i am acquiring data from a data aquisition card, i will give that a try and see if it works, thank you
(5,116 Views)
Hi Fritz,
what does the context help tell you when you move the mouse over this broken wire?
Your PID probably outputs a scalar value. Graphs don't accept scalar values - as you can see in the context help!
Either create an array from your scalar PID outputs or use a chart instead…
(5,103 Views)
How do i change the graph to double datatype? i cannot seem to figuyre this out. I have tried using the chart is the chart time dependant? i need my PID display a signal opposit to the input of the PID, and i am not that much concerned about the history.
(5,057 Views)
Hi Gerd
the contrext help tells me the following
" You have connected two terminals of different types. The type of the source is double[64-bit real(~15digit precision)]. the type of sink is waveform (DBL)."
As i asked earlier will the chart be time dependant?
(5,050 Views)
Hi Fritz,
A sarcastic answer: yes, it is time dependent as it plots new data when you supply new data…
LabVIEW comes with a lot of example VIs. And I know there are examples explaining how to use charts and graphs!
(5,040 Views)
