Im using USB-8473. Can I change battery charger parametres by sending single control message, for example by using this program attached?
Hey,
In charger manual there is example message (shown below). By sending that message I should be able to change chargers output current and voltage values. Can I do it with program attached or with my USB-8473 anyway?
m e 0x0240f010 3 0x01 0x80 0xFF sets current at 50 % and voltage at
100 %.
DLC  CMD ID    PARAM 0   PARAM 1    Meaning
3       0x01        I                U                Set current and voltage
When trying to write, CAN led blinks green so something happens there, but I think it doesn't affect like it should. I am also not sure contents of the message how it should be probably placed to example and do I need something more to that program or what? Im not very familiar with CAN and hoping that someone can push me a little bit in right direction with this matter.
Thanks in advance!
Message 1 of 1
(2,351 Views)
