Image Capturing with labview 6i
I´m wondering how I can capture an picture from my we-cam using labview ?
I would need a clear description about how it's done !
(2,875 Views)
More than likely, you will need an image acquisition card. I am not familiar with your particular camera's method of capturing images, so I cannot advise you more specifically.
You may be able to find drivers to be able to capture the images, either from the camera directly (if it is USB or some other common input method) or from the camera software.
Let us know what model and other pertinent information and we will try to help you further if we can.
(2,875 Views)
Thanx for your help !!
The camera is a Philips PCVC 750K. I've found a program that can capture pictures from the cam, but the capturing is made from the video stream(640 x 480). I need better resolution(1260 x 980) and so I need to capture images from the cam when it takes single pictures on my order !
(2,875 Views)
