Image Filter
Good day.
I once again a question that someone here has a program for image filtering Graus, median or Prewitt.
So self-programmed code, since I do not have a vision machine.
I look forward to your post
(3,186 Views)
Hi bagarman,
 If you are using labview version less than labview 2009,use mathscript node and solve your problem.
Thanks and regards,
srikrishnaNF
Srikrishna
(3,176 Views)
Hi bagarman,
the best way is to use the Vision Development Module. It provides you with all this functions and a lot more...
http://zone.ni.com/devzone/cda/tut/p/id/3470
If you don't have this module you have to implement the algorithm by your own.
http://en.wikipedia.org/wiki/Gaussian_filter
This can take a while Smiley Wink
Maybe there is a dll with this function in the google-universe...
With best regards,
Ralf N.
Application Engineering
Germany
Message Edited by ralfn on 04-07-2010 08:58 AM
(3,151 Views)
