Image Processing using Mathscript node
Hello everyone,
I am trying for image processing using mathscript node. I have connected input image to IMAQ Create but it is showing error as "u have connected 2 terminals of different type. Type of source is typedef 'IMAQ.ctl' ".I am not able to understand what is it. Please help.
Thank you
(3,882 Views)
Your VI/mathscript doesn't make much sense and it's not clear what you're trying to do. In the first line, you read an image from a filepath which is a constant. I think you should wire your file path into the mathscript node and your first line should then look like "p = imread(a);" This will read the file and store it in variable 'p'.
(blog)
(3,863 Views)
Thank you Sam_Sharp.
Actually, I am a beginner for labview,and have to do image processing. So,initially i wanted to read image and display it using mathscript node.
(3,832 Views)
