Image Updation Issue in Image Display Pallete in LabVIEW
One of my Vision application, I am using multi-loop architecture where two loops are sharing data by local variable. Data is an array of three images, which are getting updated within 300 ms, and getting shifted in a circular Queue.
 We found a discrepancy of image palette update after a long run of application. Please suggest? Is there any issue with Image palette of LabVIEW? I am using LabVIEW 2009.
Awaiting for your response.
Prakash Mahar
(3,175 Views)
Could you explain what kind of "discrepancy" you are seeing? That's a very generic term!
 You talk about "image" and sometimes "palette". What exactly updates incorrectly and how?
How long is a "long run". Seconds? Minutes? hours? days? months?
How are you "shifting images in a circular queue"? Are you simply toggling between different images or is there also a shift involved?
If you look at the task manager when running the program, how is memory use over time? (constant, increasing, etc)
Maybe you should show us a simplified example of your code.
(3,170 Views)
Hi altenbach,
thanks for your immediate response.
Following are the details...
1. Descripency : Only Last Image was showing there in Image pallete. No new image update even camera capturing is happening.
2. Image Pallete mean to say: Labview Image display control
3. Image not updation problem occured once After 8 to 10 hours, but not all the time.
4. Please check the code schemetic
5. There is no memory leak
(3,163 Views)
I don't see any code....
(3,160 Views)
Please get the attached "DUMMY Code Image Update.vi"
(3,155 Views)
