Image blackout after golden template matching
Hi
I am trying to use IMAQ Compare Golden Template to campare the image with the standard template.
I am using this function in a subVI.As soon as the subVI gets closed the image blacks out and only I could see is the black screen in my image indicator.
Ninad Regundwar
Junior Engineer | ARAV Technologies | www.aravtech.com
(2,511 Views)
Hi Ninad,
-Did you go through the example provided in the NI?
-Go to Help>>Find Examples>>Golden Template Inspection Example
-My initial guess is, please check the Image indicator palette and use appropriate one.
-If you use gray scale palette type for binary image, you'll face these type of issues.
-There is a dedicated forum category for machine vision-suggest you post these vision related queries there.
-Please let me know if you have any other queries.
uday
(2,500 Views)
