Image bleed through On A Dialog Control In LV
I am using a Dialog Control to control a lot of user interfaces in an application. In addition, I hide then make visible some other controls that sit in the dialog control. In 32bit color, this works and looks great. On some machines with low bit color settings, I am getting a ghosting effect. Looks like some of the other controls bleeding through. Any ideas on how to fix. I am using LV 6.1 now but should get my LV 7.1 upgrade this week.
(2,716 Views)
If you have specific controls or indicators that exhibit this effect, you may want to replace those objects. I chased down one of these in LV 6.1 and that fixed the problem. I was suprised!
I was suprised because it seems that every other grphics related anomaly that I have noticed in LV were always fixed by using the latest and greatest screen drivers or by changing the hardware acceleration settings for the display. In my experience LV has always played the "graphic update game" correctly. It the hardware/drivers that are not keeping up.
Ben
(2,716 Views)
