Image can't be displayed synchronous
Hi Folks
Here is a question about the image obtained from the camera can't be displayed synchronous in the indicator. What I want to do is to display the raw image in the indicator( called "Image"). I already set the indicator as synchronous display, but when I ran it, image couldn't be displayed constantly, always flashed. I probed the wire connecting to the indicator, but the image out gave a constantly, accumulated image. That's so weird that the indicator on the front panel couldn't show the image constantly.
I attached the picture of block diagram and front panel.
Thanks for your help.
(2,948 Views)
also attach the vi
Thank you so much.
Lu
(2,924 Views)
Accepted by topic author shuchong
If you right-click the image display and turn on snapshot mode, does it make any difference?
-Zach
(2,889 Views)
That seems work. Thank you !
(2,869 Views)
