Image extraction without IMAQ, using Read JPEG file.vi
Under Graphics and Sounds there's a VI name
Read JPEG File.vi-- can I extract numberical data from this vi?
if not, what is this VI's function.
and what i want to do is to read pixel info (RGb or HSL) from the flattened image, *without* using IMAQ. (I persoanlly think IMAQ is too rigid....)
thanks you
(2,735 Views)
You should use the Unflatten Pixmap.vi function. This returns 2D arrays (for 24, 8, 4,1 bit according to image depth).
I attach a sample vi that shows it.
Good luck,
Alberto
(2,735 Views)
