Image overlay with NI Vision
Hello to all,
I need your help please with a NI vision problem.
I am taking two pictures with cameras. On one is a "+" and on the other four squares. In the second step I want to "superimpose" the squares of picture 2 to picture 1.
My first idea was to find the squares with pattern matching and to insert their coordinates as ROI into image 1. Unfortunately this fails because the coordinates I get with the Pattern Matching land on completely different places in image 2 than the squares. Furthermore I can only insert one ROI into image 1, but I need all four...
Now my questions to you: Is this feasible? Or do I think/do something wrong? Do you have other ideas how to implement this?
About the software, I use LabView 2014 and NI Vision 2016.
Thanks a lot to all of you!
MfG Roadrunner
(2,041 Views)
Accepted by topic author Roadrunner51
Use IMAQ Group ROIs to merge an array of ROIs into one.
(2,037 Views)
Hello RamonG!
Thank you for your quick replay! I trie it tomorrow.
(2,031 Views)
