Image processing doesn't show
Hi!
I am trying to do image processing, where it will detect the object and box it up when detected.
However, I did not manage to detect the object, which in this case, a masking tape.
Can anyone tell me what is wrong and how to solve it?
Below is the attached VI that I have done.
(3,775 Views)
Before we can answer we also need to see the kind of image you are processing.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,760 Views)
This is the image i was trying to get.
(3,755 Views)
Is this what the image you will be acquiring will look like? Won't the tape be coming down a production line or something?
Mike...
LabVIEW Champion
(3,744 Views)
No. This is just for testing purpose. I don't have the actual image as it is for an obstacle in a competition.
However, the obstacle is also a ring as well.
I just found a way to detect the object.
I used geometric matching instead of pattern matching, but it was able to detect other things such as my laptop as well.
Is there a way to detect the image and change the diameter of the ring so that it is able to detect other rings with a larger diameter?
Thanks for your help.
Attached below are the changes i have made and the images it detected.
(3,741 Views)
