Image processing for QR Code detection in Labview
I have image containing 10 QR codes. I want to extract and decode this codes using Labview.
I don't want to use NI computer vision library. What are the options here? Using OpenCV?
(2,926 Views)
If you are on Windows, OpenCV + EmguCV (a .NET wrapper) are the easiest to work with in LV.
On Linux, OpenCV + Python.
(2,857 Views)
EmguCV must be used together with OpenCV to work with LV?
(2,837 Views)
EmguCV is a OpenCV NET wrapper. So, yes, you must use them together.
(2,826 Views)
Please give me some advice how to start with using Emgu + OpenCV.
What source code for Emgu and OpenCV must be downloaded and from where?
How to start using code in Labview to implement some basic functions from OpenCV Liraries?
(2,776 Views)
