Image processing with VA in myRIO: Error code -63193
I run an image processing with vision assistant (VA) in myRIO. When I run the Host.vi under RT, I get the following error:
The error said:
Error -63193 occurred at Invoke Method: FIFO.Acquire Write Region in NI_VDM_FPGA_Basics.lvlib.IMAQ FPGA Image Transfer to Target U32.vi:1980001->Host.vi.
The possible reasons: The requested feature is not supported.
Then, I try to follow the steps as stated in this link https://forums.ni.com/t5/LabVIEW/Vision-FPGA-in-myRIO/td-p/3266599. My question is how to add "Device Code" under myRIO? I can't find the device code.
Could you advise? Thank you for your time in advance.
(2,806 Views)
In the Open FPGA reference node you are passing in the resource string as "rio://<hostname>/rio0".  This opens a remote session which doesn't support the Acquire Region function.  Instead you want to change the resource string to just "rio0".  That will open a local session that supports the Acquire Region function.
I'm going to look into improving this error code.
(2,777 Views)
Hi Michael,
Is it any other options or advice to avoid the error?
TQVM
(2,762 Views)
