Image processing
how to connect this broken line using image processing? I want to convert image 1 in image 2. image1image1image2image2
I have attached the vi and the images.
please help
thanks in advance.
Message 1 of 13
(5,285 Views)
Accepted by topic author MAC08
Hi MAC,
without using IMAQ I would use this algorithm:
- get the image data as array of pixel color values
- process the array column-wise
- search for the line color in each column and keep the index of the found pixel
- after scanning all columns you can redraw the line using the found pixel coordinates and connect each pixel point by a line…
Message 2 of 13
(5,252 Views)
i am trying to do so but not getting desired result can you provide me sample a sample vi.
Message 3 of 13
(5,165 Views)
Hi MAC,
what have you tried?
Which result did you get?
Why don't you attach your VI with some useful image data?
Message 4 of 13
(5,156 Views)
i have attached the vi and image. i want to join these lines and find array of newly formed pixel values.
Message 5 of 13
(5,151 Views)
Hi MAC,
you forgot to include some useful data in your VI!
Please run your VI to display an image and some values in the "Image Pixels (U8)" indicator.
Then stop the VI. (Why is there no stop button in the loop?)
Then Edit -> Set current values as default.
Then save the VI and attach it again…
Message 6 of 13
(5,146 Views)
Hi
I have made the changes as you suggested.
Regards
MAC
Message 7 of 13
(5,137 Views)
Hi MAC,
your VI still doesn't contain any data…
But you included that image, so I could play with it:
It's not perfect, but gives the requested plot…
Message 8 of 13
(5,130 Views)
hi GerdW,
i want to invert the graph. how i can do that?
i need some suggestion.
best regards,
MAC
Message 9 of 13
(5,055 Views)
Hi MAC,
please define the term "invert the graph"!
Do you want to exchange colors?
Message 10 of 13
(5,049 Views)
